Like every one else I suppose, I had a couple of 2 axle cabeese lying around without any real purpose. I just don’t like them. I also had one of the hideous gold belt gondola cars without a home, so decided to do a bit of hacking away.
I removed the steps from one of the cabeese, and did some carving for fit.
and after removing all protrusions from where it and the sides of the body would mount, attached the steps to the end.
I cut peices from the lower edge of the second (donor) caboose so the body would extend to the bottom of the now-flat car.
I used spray primer allowed to dry to near putty to fill the gap after assembly, then carved the board slot grooves back in with the edge of a hobby knife.
The roof had to go, so I went with a tin roof. I had no intention of trying to find the hole for the stove pipe, so used a wooden dowel and cut it and the stock stove pipe at 45 degree angles, then blocked out one of the windows.
Had to ‘man’ the caboose. This is a Lionel 1/24th scale dude…
I attempted to replicate a double block and tackle crane in here, with marginal sucess. It looks okay from 3 or 4 feet away I suppose.
I still need to hit it with flat clear, then a bit more weathering.
