Terry, how do you know your charger charged the pack you said was dead? After you charged the pack, what was the voltage reading?
Here’s how you can test to see which device is making your loco stutter? Take the Airwire board out of the mix and hookup the battery or your DC power supply directly to the motors, only do this for a second or two. Set the DC power supply at 12V @ 1 amp. If the motors run smoothly, then it’s the Airwire board.
John, at .5C charge rating on your 2200mah pack is 600mah over the maximum capacity those cells can be charged at. They are only rated at 500mah per hour rate, I would stay with that setting, or you will burn up your back and possibly balloon the cells and catch them on fire!
Also, there are no PCB’s that regulate the amount of amp hours you can charge a lithium battery. The PCB only regulates two things, (1) voltage limts while charging/discharging, (2) the amount of amps that the pack will discharge at. You and your charger sets the amount of current and voltage limits that your pack is charged at not the PCB. Once the voltage limit of reached after the first charging cycle, the PCB will automatically disconnect current coming into the pack. Then to gain more “runtime” the PCB needs (cycle through 3 - 5 times) to learn the capacity of the pack, that’s way your pack will never be fully charged on the first charging cycle.
The corrosion is due to the cell venting, that is why you see a green and/or white powered film along the end. You pack is dead. A cell vents for two reasons, over-charging and/or over-discharging. My guess, it was over-charging. The Tenergy cells are not manufactured for high drain. Unlike my SC2200, HC3000, and HRD2500mah packs that can be discharge at 10A - 25A bursts. Purchasing a cheap pack (in price) sometimes you don’t get your money’s worth out of the pack? Plus, I think Tenergy only has a 6 month warranty?
Also, because your cells measure below nominal voltage of the cell, (3V per cell) doesn’t mean your PCB is bad? It could be beacuse your not using a DPDT switch in your wiring scheme and the pack is discharging when you switch the Aristocraft “Battery/Track” switch to “Track.” Your still discharging the battery-pack.
A lithium battery-pack can never be “jumped started.” You can reset the PCB if it’s not taking a charge, but this would be done at the manufacturer.
Rick Isard
Cordless Renovations, LLC
RCS America
