As reported on MLS:
http://www.mylargescale.com/Community/Forums/tabid/56/forumid/17/postid/56931/view/topic/tpage/2/Default.aspx
Quote:and:
. . . 12/30/2008 8:15 AM Quote ReplyAlert Just received and put into service my first (last?) Davenport. I was initially impressed with the construction and detail. I wired it for battery operation and put it to work. I was stunned when I found out it has the same flaw (with a single power truck) as do the two truck Shays! This flaw is - when going down hill (2-3% grade) the power train binds up releases, binds up release … etc. I won’t go into this as the Shay problem has been beat to death here on MLS and if you are interested I am sure you can locate a lot of it in the archives. For its size the little sucker is a good puller on flat ground or up hill. Best, Ted . . . .
http://www.girr.org/girr/tips/tips10/davenport_surging.mov
from Our Buddy George!..here is his work page on the Davenport:
http://www.girr.org/girr/tips/tips10/davenport_tips.html
anyone else suffering the same with grades? I think I just saved $150 (for now)
cale
