I picked up a sound card from Dallee; Alco Road Eng. Diesel Sound. All of the installation instructions assume track power. I am battery. Now my question is, the way I understand this to work, is it reads the increase in voltage from the track to gauge the throttle response. It also requires an auxiliary battery to operate the sound when at idle.
I assume I can substitute track power with the power output from my loco control board. So as voltage from the loco control board increases to run the loco it will be the same as recieving track power. Am I right in this?
Also can I ditch the auxiliary battery altogether and wire these leads directly to my main battery. It says battery voltage can be 9 volts and can not exceed 35v. So 14.4 is right in the wheel house.
Any flaws on my thinking?
