OK folks, on to the grab irons, and for you Rooster, progress pics.
Following is how I made a fixture for manufacturing grab irons from copper wire (16 AWG - I think). First pic is of the fixture after layout, drilling and installing half of the guide pins. The guide pins are made from steel welding wire I have for my oxy-acetylene torches, 1/16" diameter. The holes were drilled in the aluninum with a #53 drill bit (.059 diameter). I then took a length of welding wire (about 6-8 inches), chucked it in my cordless drill and decreased the diameter to about .061 with some emery paper. Next I cut three pieces about 1/2 - 3/4 inches long and cleaned up and put a small chamfer on one end to help guide it into the hole, and tapped / drove the pins into the holes. This is an interference fit and should keep the pins in place a long time.
Next pic shows all the pins installed and cut to length using an old fashioned Dremel cut-off wheel with the old fashioned fragile as the dickens super thin wheels. Jewelers files finished the top edges to remove all the burrs.
The next shot shows a grab iron in the first stage of forming in the fixture. I gave up trying to figure the length of wire to pre cut and just start at one end and work my way to the other using finger and a pair of flat smooth face pliars.
For the next part of the forming process, remove the grab iron from the fixture, turn it around and put it back in the fixture as shown below.
I use a special tool for sheet metal working that is used to turn up edges and flatten joints to hold the grab iron in place in the fixture from the long side to the portion of the grab iron that extends off the fixture is free to be bent to a 90 degree angle. I don’t have a picture holding the fixture, but the special tool is shown below.
A grab iron after bending still in the fixture.
And finally a couple of completed grab irons. I plan to attempt to solder the ‘eyes’ closed in an effort to increase the strength of the soft wire.
Mine is not the only way to make grab irons, but it will make them very consistant, and considering I predrill all the beams for them consistancy is a necessity.
Until the next installment…
