I only took two pictures. A before with Rail Boss Plus Hobby and a newer Phoenix board and good cable management, but no battery…
And after with only the RailPro module and the battery. No cable management happeningg yet…
The sound in the video doesn’t do it justice. The low-end is awesome! This system shines with a big speaker!
I should explain why there is a rat’s nest of wire for a simple trail car. 1st up, Bi-Color LEDs at both ends to quickly indicate direction of travel since the lights on the loco don’t light when stopped. This requires a multi-conductor cable from front to rear and tied to the lighting output of RailPro. Next, a multi-speaker set up that supports a front mounted speaker in the loco plus the on-board Mini 3.5 plus a front mounted speaker in a second loco if MUed. That requires a 3 conductor cable front-to-back (support for push-me/pull you configuration) that is tied to the RailPro speaker outputs and a selector switch. Finally, also in support of push-me/pull you configuration, the motor output of RailPro has plugs on both ends.
