It started out in 3 segments but I decided I needed 4 segments for the look I wanted. Like a lot of my models this bridge could be disassembled as well however it must be done with a hacksaw!
I struggled with what I was going to do for a deck. I really like the modern concrete decks however I do have a good bit of old growth redwood that I rescued from a fiery eternity because the person thought it was stained pine.
So I took advantage of the semi nice day yesterday and ripped down some stock to 1/2" x 1/2"
That was as far as I got yesterday and the ties were removed and painted. I opted to leave the spacing as such so I could just pop in sectional track as opposed to putting them closer together and hand spiking the rails.
Now I have another issue to struggle with as I built the bridge to go here. ^^^^^^^^^^^^^^^^^^^^^
I changed the layout configuration last spring and I needed a double track thru truss as opposed to a single track. I placed the bridge at the other end of the layout on top of the deck truss I built and honestly I may have to add the new bridge to that other span? Not sure yet however if I do then it would give me a reason to build another bridge???
Croissants are in the post!
