I put in the adapta board with a G3 Decoder and Phoenix P8 sound. Everything wired according to specs. The decoder is not talking to the throttle, even with initial power up, the green light is steady with them G3, but the red light does not come on, which should happen even before it is programmed, as it knows the throttle found the decoder, even before programming. programmed the address and frequency, still nothing. I even did a reset for the G3. I did contact CVP about the adapta board and believed the internal set up was the same as the GP40 as with the Dash 9.
I did isolate the track power pickups as instructed. I did ask Phoenix if it was ok to plug the sound plug from the P8 into the sound port on the Dash 9’s main board, they said yes, but no sound either. I have read a bunch of articles. I even read an install procedure from a fellow from the Ottawa Garden Railroad Society in Canada. Except he was using Aristo sound and DCC, but the install was very similar. I reached out to them, but still no reply. I don’t think they check their forums very often, and some of their posts were pretty old. This guy did do a step I have not done that maybe might have some effect but not sure. I will enclose the link to the page.
Scroll up or down to the section “REMOVING THE MU CONNECTORS” I did not think this made much sense to do as the DPDT on board switches would just stay in the “on” position, with the exception Battery/Track Power switch, left in “battery” position. IE:
Battery/Track Power “battery” position
Smoke “on”
Lights “on”
Motor “on”
And the DPDT installed power switch I installed from the battery controls all power going to everything. I was able to reach out to a fellow from Large Scale Central on line forum, and he concurred that it looked like I did everything right. Again, I would appreciate any help, referral or to pass this on, including my email address.
Thanks
Dave
