I am just getting down to making the cut levers for the cabooses , which , as some of you may know , are not always the curved rod type , but a lever of flat (?) bar .
The lever has a hand hold at the outboard end , and is pivoted on a stand-off about half way along its length . It has a joggle in it to stand the bar off the buffer beam .( you may not call it a buffer beam , I know) The photos that I have of the device are not too bad , but I am puzzzled over one aspect . The inboard end of the lever seems to have a round rod coming off the end , rather than making the lever long enough to reach the uncoupling loop (ring?) . Is this interpretation correct ? I can see no connection to the coupler I assume it is a short length of chain . Anybody know ? Any photos of the area ?
Mike
I forgot to mention , the cabooses are the ones I posted before .
