I’m in process of building a tunnel with an increasing radius curve. there is one 6" strretch that the side clearance from outside rail to side wall drops to 2.7125".
While I don’t have plans to run heavyweights or modern length freight cars I would like to be able to run some of the larger steam profile engines like the 3 truck shay, a J3 Hudson, or Unitah mallet.
I have not found a difinitive resource that outlines curve overhangs and limitations. Any sources? or experience?
thanks in advance for input…
mark
The thing to do is set up a mockup of the curve and run the locomotive through the curve to see what the clearance is. On steam locomotives watch the cab. That is what usually gets me for clearance on curves. Straight aways is usually the cylinders that like to clear things out like bridge abutments.
