OK guys, here’s what i need to do. I’m building about 12 feet of trestle on my mainline loop, part of it goes over the small lake/river(real running water). I’ve settled on a piling in the lake for center support, which leaves a bridge section span of 31 inches. This loop is a 10’ diam. curve. I want to use a decked truss bridge. My plan was to use a span of 7 inches wide, made up of 3 trusses to handle the curvature. Heres the single biggest question, Will this work? And if so, how would the decking, stringers, ties be laid out on the curve on top of a straight bridge? 2 or 3 stringers? or no stringers and 7 inch ties closely spaced across the top of the trusses?
BTW 1:20.3, code 332 stainless, track 26" above water line.
