Hehehe, ok, I think I didn’t make myself clear here
What I was getting at, wasn’t to make a “steam” type engine for normal usage, but use a similar mechanical structuring, BUT, using gas “instead” of steam.
And as I mentioned, yes, it would need to deal with the exhaust, but looking at how the basic and I mean VERY basic set up that the two piston steam setup uses, I would think that somehow the top piston, which is the one that let’s the steam come in one side and then the other and then back to the other side and back again repeating itself over and over, would or could be a more efficient method then the current zillion parts setup that modern day gas motors all use, i.e. all the valve rods and such and like that, wowsers, just look at the next Ford commercial where they show their newest engine and you’ll see what I mean LOL
That thing is totally over loaded with far too many moving parts just to do the same old exact things that gas engines have been doing since they invented them and really nothing since has much changed at all.
I would think that after nearly 150 years of gas engines that by this point in time they’d have come up with something better, more efficient and not that lame Mazda rotary motor, that could of had some chance had they designed that thing correctly too.
And yes, I thought of the two stroke engine as well, but that requires a bit lack of stability, at least for normal users who really wouldn’t have the slightest clue how to keep the upkeep on them and anyone who has ridden on and dwelt with two stroke bikes, like I have in my past life, will tell you that they are not great for sitting still in an idle mode, where as a 4 stroke can handle all that with pretty much zero issues.
So, to me, it feels like, this sort of steam engine is really soooo close and right there on the edge of something great, but no one bothers to look at them with a new eye and thus dismisses them out of hand, mostly.
What I plan to do, since just looking at this little GIF animation doesn’t help much, is to after I finish modeling that part for my steam engine, is to then save out that part of the workings and see if I can modify it in 3D where then I can rotate the thing around while it is in animation mode (playing) and that should be able to give me some better insight to how things look from other view points and maybe see what it is I and everyone is missing, that is if we all are truly missing something, which I think we all are.
OK, now, for the GIF animation above, I am viewing it like this, so we all can follow my mindset
Let’s pretend that all the red is the fuel.
Then, let’s pretend that the white areas are of course the exhaust.
I think there could be missing a couple of openings there or something to allow the expulsion of the exhaust and the injection of the fuel.
Seems to me, that without making it like the standard two stroke system, you could maybe “fake” the two stroke theme while keeping the concepts of the four stroke model intact, no?
Hope that last part made some sort of sense to you all? hehehe
What keeps tripping me out too, is how as large as the main piston is, the actual thing that runs it all, is some tiny little arm with a tiny little piston of it’s own that does all the real work of injecting the gas (steam, fumes, vapor, whatever the real words would be?).
Look at how all it does is barely move and IT allows EVERYTHING to come and go, simply amazing in it’s simplicity.
So, I say, time to modernize this concept and get on with the gas saving area, instead of all these expensive and highly lame so called “green” vehicles they keep trying to pawn off on the American public these days LOL
Quote:
Expect that would lead to more parts, weight, complexity.
Prime advantage, as far as my understanding, of gas motors is power to weight ratio.
Maintenance access would be an issue too.
And this is why I feel using the steam engine basic model would actually be "less" parts involved then the current gas engines are, with all those push rod springs and so on.
I'm a Nascar geek and every year I study on the engines they use and just look at the piston only firing in ONE direction and (IMHO) "wasting" the return movement of that piston, other then to rid itself of burnt gas.
Lame LOL
OK, Don’t want to write too long here, I have that tendency to sometimes do that, so be ware hehehe
thanx too guys for your own interest and Joe, I’ll look at those links right now…md
