Bruce,
Why not make the joint overlapping?
See posts 26-28 of this thread where I did an overlapping joint test of the top/middle/bottom panel.
I had an issue with the thin lap curling, but that was before I had the PLA+ filament tuned in, guess I should try it again. When I removed the lap I found that the butt joint worked well and decided the lap wasn’t worth the effort.
If I do use a lap joint, I still have the issue of hiding that joint at the surface:
I found that if I held the joint flush there is ever so slight a pucker on the edged that will require blending of some sort…
