Rather than use Kadees for this car, what I have done with mine in that body style is to take the USA coupler and file off a bit of the tang so it will fit through the coupler pocket. You have to do a bit of shimming, and then for security you can drill through the boxcar floor so you can through bolt the coupler, but it works great!. The coupler comes out the pocket, just like it is supposed to do, and you don’t have to buy any Kadees.
It has very easily gone around 10 ft diameter curves on my layout, but I’ve had it fail (derail) on a 6 ft diameter at a friend’s layout. I’ve run several cars back to back on the same ten foot diameter curves without problem. It matches the height gauge very closely, close enough that I’ve had no problems with uncoupling. And, it looks GREAT!
It’s not as bad as…say Bachmann…where all you have to do is look at them and they come apart.
