In the middle of this posting survey we had our Fall OPs Session. What this provided was that people that were “true” to their scale found that there equipment couldn’t run on visiting layouts, both mine and AndyC’s. It made an interesting analysis on this little study.
Basically it seems to me to come down to a need to use couplers like Kadees or those that are very compatible to Kadees and set to a height using the Kadee gauge. Now this may look like I want everyone to agree with what I do. Yeah, okay. But over the years I’ve put a lot of thought in to this, made lots of compromises and tested and tested the different couplers. Personally, I like the Accucraft style and uncoupling gear best. But the linkage is to fragile and the chances of a first time coupling in a shed 20 feet from you is a crap shoot. So I have settled on the Kadee “G’s”, set at the Kadee gauge height. They match up with the Kadee “#1’s” like what Fred, Ken and Andy use, plus they also match with Accucraft, Bachmann, Delton, USA and Aristo-Craft, if those are set at a close height.
Now, nobody has to follow this opinion and you can stick with your own ways, but if you ever want to take your equipment to anyone else’s railroad or have people over to your layout, you’ve got to compromise and come at least close to equal ground, if you wnat equipment to be interchanged.
That common ground seems to be a Kadee coupler height gauge. #1 or G, it doesn’t matter. They are compatible to each other, so that make your equipment, no matter what coupler, some what compatible. The height of those gauges are 1 1/8 above the rail to the vertical center of the coupler, in 1:20.3 that’s 24 inches and I don’t know what it is with in 1/29th with the smaller #1’s, but it seems to be close… Any couplers set to those heights have a chance to couple, sometimes with a lift over and wedge the closed couplers together, but they will work without bent paperclips or bread ties and I guess that is a step in the right direction.
I thank you for answering my questions and giving your opinions, maybe some one will be able to use this dribble.
