Coupler change
Is there a trick to attaching the hook and loop coupler system to a car? I cannot for the life of me manage this. I get every thing aligned and then when I go to place it, bam it all goes capoohy. Is there a special tool or technique for this procedure? The car I bought, Heinz 57, came with kadees and all of my stock and engines are USA. I really want to incorporate this car into my train, so any advice would be most appreciated.
Thanks
If the KDs are mounted on the talgo (tow bar on the truck) unscrew the KD and use the same screw and hole for the HnL.
Sometimes you have to trim the talgo a little shorter.
Thanks will try this.
