Hello everyone, this is our New C-10 Carrier Battery-Powered Trailing-Car Circuit Board…below is a 40ft. AMS double door box-car base with ball-bearing wheels…the trailing car circuit board package includes: 3W 8ohm speaker with plexi-glass cover, raised charging circuit board with 1.5amp wall adaptor charger, 14.4V 3800mah Nimh battery-pack, double pole - double throw switch with LED light and inline 5amp fuse, 8 stand-offs or rubber feet. To the right end is Aristocraft TE Revolution circuit board and Dallee Diesel Sound Card…not included. Let me add that this is the first of many different versions and sizes of the same style of boards, we will offer boards to handle lithium-ion batteries up to 22.2 volts, and dual battery systems to handle 24 volts.
View below: Closer view of the C-10 Carrier Board.
View below: Starting from the left: double pole-double throw switch with charging LED light, inline 5amp glass fuse, and raised single station charging circuit board with DC wall adaptor plug-in for our 1.5amp wall charger.
View below: speaker and power input (J1) there is one output for the speaker and two inputs for additional power, so you can hookup additional lights in trailing passenger cars.
View below: closer view of the charging circuit board, power adapters, switches and power connections.
View below: rear view of the 14.4V 4/3A 3800mah Nimh battery-pack, 8 & 10pin headers for your controller circuit board, placement for your sound card, (J4) power connections, (J3) 10pin mirrored adaptor plug-ins, (J2) power inputs and sound card output to the speaker.
View below: 8 & 10 pin header plug-ins, these header plug’s can be removed if your controller card does not have header pins.
View below: (J7) (J6) 8 & 10pin power headers, with two diodes.
View below: our header pins match inputs from Aristocraft, OSI, RCS, Airwire, and soon Locolinc.
View below: RCS board match.
View below: QSI board match.
View below: 10 connector output matches the 10 pin header output from the controller board, (J4) power, (H1) diode connection, (J3) 10 pin mirrored output to engine connection, (J2) speaker card output with power input. Please note: that (J2) & (J4) power / speaker connections will be reversed.
View below: reverse look at the speaker card placement.
View below: backside of the battery shows the power connection input into the circuit board, along with the circuit board charging plug-in and speaker plug-in.
The dimensions of the circuit board is 11" length by 3 1/4" width, we can also adjust the DC connection to vertical if the side box-car door does not align correctly. We will have more details along with additional photo’s and pricing on our website within the next few days. After talking with the best installers and several enthusiasts, we have decided to add an external DC plug-in along with an external Run/Off/Charge switch that you can plug-in to the board and run it to an external location on your box-car so you have easy access to the charging / operation jacks without opening or closing the doors. Thanks JJ and Robert Buck… We can also customize this board to various sizes to fit your needs. I appreciate your input and comments, Rick Isard Cordless Renovations www.cordlessrenovations.com
