I’ve had a USA GP-9 sitting on the shelf idle for a number of years. It was my first LS loco, purchased in 2001. I recently decided to strip out it’s Phoenix Big Sound 97 board to use in my Connie conversion.
While I had the loco open I noticed how devilishly simple it would be to adapt this loco to use my 1:24/1:29 R/C battery & Sound trail car. All one needs to do is unplug the trucks from the circuit board Track1 and Track2 and extend these connections to the front and rear of the engine!
I threw a battery, ESC and RX unit on the open frame just to test it out. Even with the skates still attached (I will remove them) the low-speed performance was awesome. Many times better than it ever was on track power.
The decision was made to complete the conversion so New Haven 1224 can once again be used in plow service on the C.V.S.Ry.
I will need to do some minor repairs first. This Geep has had a hard life. Several of the shell mounting posts are snapped off. They will be repaired and reinforced. The front steps were knocked off on more than one occasion. They will be re-attached. I previously used a Hook & Loop coupler on the rear with a transition car to allow the loco to negotiate R1 curves. I’ve since eliminated all but a few sidings that use R1 so Geep 1224 will get my standard Delton couplers front and rear.
Film at 11.
BTW - As I mentioned, 1224 was used a lot in plow service. The Phoenix board was mounted on the smoke heat sink directly under that fans. It’s no surprise that it got wet on occasion from snow. When I removed the board I was concerned about corrosion that had formed bridging some of the tiny connections to the large chip in the bottom of the board. Using a trick I learned from a cell phone tech, I scrubbed the board with alcohol and a tooth brush. After giving the board 10 minutes or so to dry I powered it up for a test. 100% functional!!!
The chips will be sent off to Phoenix for reprogramming to steam sounds for the Connie. 1224’s speaker will be fed from the 2K2 board in the trail car through a 3 pin plug.
