The Bachmann tanks scale out (in 1:20.3) to 6’ wide by almost 23’ long. I don’t have an AMS car to measure, but published drawings of the prototype for the AMS car has a tank a bit over 6’ wide and around 24’ long. Without locating my drawings of the EBT’s tank car, I do recall the B’mann tank measuring equally favorably against that prototype in 1:20, though I think it was a bit shorter. The Conoco car drawing states that the tank capacity was 5000 gallons, where the EBT’s tank had a capacity of 6000 gallons. The UTLX (Gramps) cars had capacities between 6,000 and 6,500 gallons.
(http://home.comcast.net/~kcstrong/trr/pics/gallery/alongcoles.jpg)
While not the best photo, here’s my version of the EBT tank “up-scaled” to 1:20. Actually, it’s more like 1:21, because when I built this, I had not yet made the firm commitment to 1:20.3, so the flat car is a touch narrower than it should be so it would mix in better with my 1:22 and 1:24 equipment. Ric, Vance Bass wrote an article a few years ago about kitbashing three standard Bachmann boxcars into two D&RGW box cars in 1:20.3. The result was quite convincing, and served as the impetus behind my conversion to EBT “1st generation” boxcars. If I recall, he added a bit of height to the car via a new letterboard, but the width stayed the same. (The length was extended through splicing two cars together.) I don’t know if the article is online somewhere, or if he sent it to me as a .pdf. If you’re not in the mood to splice the cars, there are a fair number of examples of 25’ boxcars that lasted until the ends of their railroads. Granted, their longevity was probably due to the fact that the railroad couldn’t afford to replace them, but still, they were out there. Here’s one that I did from a B’mann box car:
(http://1stclass.mylargescale.com/eastbroadtop/TVRR207/TVRR20711.jpg)
Photos in progress: http://archive.mylargescale.com/forum/topic.asp?TOPIC_ID=37979 Later, K
