Hello,
I have two locations on my railroad that have wye’s to turn locomotives. those of you that have been to my railroad know about the need to duck under, or raise a lift out section to complete the turning operation. what I would like to do is to use the cheap servos available on eBay and elsewhere to throw these turnouts, preferably by selecting the route desired via pushbutton on fascia board.
what do you recommend for support equipment to perform this function. I will need to tune servo throw distance, I do not have DCC, but do use Air wire. if that is of any help. basically need to align two of the three servos every time I push a button, regardless of the turnouts prior position.
lets see your low cost PNP solutions.
AL P.
