After much peer pressure I am starting a thread on the topic of modeling the Conrail Office Car Special. Some of you have surely followed the construction of Theater Car #9, but that is but one of several cars in the OCS.
I am going to start this thread by discussing the E-8 for my train. We’ll touch on the theater car as well as at least two others I have plans for, perhaps more as time goes on and skills develop.
Aristo makes a nice E-8 and the Conrail OCS used three of them, but the two from the PRR origins had much different bits on the roof, mufflers and fans and what not. But the former Erire loco has the right-looking bits on the roof so less modification is needed to model Conrail E-8 #4022.
Much credit for the E-8 model must go to a helpful friend named Russ who happens to be the president of the Conrail Historical Society.
Starting with an undercoated Aristo E-8 ditch lights were installed:
Then the side port holes were filled in:
A new door for the front needed to be fabricated as the undercoated model had the second lower headlight:
Then more work on the nose could begin to add more grab irons:
Those carefully inspecting the photos should also notice the fabricated horn mount at the top. A new horn was made by first cutting up a brass three-chime horn:
And making the horns point in new directions:
Then the loco was primed and painted:
Then lettered:
At first the can-opener logos didn’t have long enough legs/tracks coming out of them (as seen in the above photo) but I cut some decal pieces and extended them. I also weathered coupler up front to make it a little more realistic. It had previously been shortened to give a better look to the nose.
In the next post I will most chronologically with the build and highlight Mr. Rooster’s fine construction of the Theater Car, CR OCS #9. After that will be #12, then #27, and if you’re all good boys and girls perhaps #3… after that is anyone’s guess.
