I’m not at home to see test the geometry of a 2’ radius curve relative to the drivers on the Connie. My gut tells me you should be fine, as the offset shifts from both blind drivers being offset to the inside of the curve to one being inside and one being outside. The wheelbase is compact enough to where I don’t think you’ll drop the wheels off the railhead. If I recall, Dave Goodson (TOC) said the loco would go around a 2.5’ radius curve with only a modification to the deck plate between loco and tender. A 2’ radius shouldn’t be too much more of a stretch with the altered wheel geometry. I can check when I get home.
Having said that, I think the suspension or wheel overhang would be the least of your troubles. That’s an awfully large loco to try to get around a 2’ radius curve. The overhang to the back of the cab will be dramatic. If you move the flanged driver from the #4 to #3 axle, you’re going to increase this overhang. (I might consider swapping the #1 and #2 drivers instead for that reason.) Also, the tender drawbar attaches to the loco towards the back of the frame. The further the frame moves out from the center of the track, the more askew the drawbar will get relative to the tender, whose pivot pin will be pretty near the center of the track given its proximity to the pivot point of the front truck. That’s going to do two things. First, it’s going to put lateral pressure on the tender as it goes around the curve, especially as it tries to drag a train through the curve as well. That could lead to derailments. You’re going to need a long drawbar to keep the tender from hitting the locomotive as it goes around the curves; probably longer than the stock one. I’d consider mounting it much further forward on the locomotive so its pivot point is closer to the center of the rails. You’ll also need to replace the rear truck with one that has a truck-mounted coupler.
In terms of adding a trailing truck to it, check out David Fletcher’s conversions of the Connie to a K-27. They look great, but you’re making an even longer loco, then, which will only exacerbate the issues relative to getting it around a 2’ radius curve.
To be frank, I can’t think of a reason why this wouldn’t work, but I don’t know that it’s something I’d put a whole lot of energy pursuing. The wheels are easy enough to swap out since they just press onto the axles. Try it, see what happens. The worst is that it doesn’t work, which puts you back where you are now.
