After a month or two in the weather, the decals I printed using a color laser are already showing signs of wear.
The decals were sprayed with clear acrylic after printing as well as after installation.
The decals printed using the clear (blue) waterslide paper have an entirely different problem than those printed on the white waterslide paper.
The “clear” decals have already faded severely. The red colors are the most affected. Black, doesn’t seem to have fade at all.
The “white” decals are not fading. However, the printing has crumbled off, mostly around the edges.
If they continue to degrade, I’ll have to replace the decals before the buildings have even been installed on the RR.
I will try using several coats of clearcoat next time. That may help the crumbling print problem with the “white” paper.
Any suggestions on how to fix the extreme UV fade problem with the “clear” paper?
