Who still makes and or sells code 250 aluminum rail and switches.
Asking for a friend.
Llagas Creek still does afaik. That is what I used to build my railroad.
Track: Assembled Track ā Llagas Creek Railways
Turnouts: Turnouts ā Llagas Creek Railways
Micro engineering https://www.microengineering.com/
, Ligalas creek https://llagascreekrailways.com/
, sunset valley Home
What size turnouts do you need? Iāve got some Llagas Creek #4 frogs I donāt need at the moment.
I want to jump in here with a question. A tree limb wiped out one of my aristo-craft right hand switches. What were the size switches that they offered. It is not the big one. But I do not remember what the other sizes were. I need to see if I can find one or something similar to replace it. Thanks.
I have a few hundred feet of used Sunset Valley track that I will sell dirt cheap. It was removed when I dismantled my layout. I also have extra Sunset Valley and Accucraft tie strip. This would be pickup only in Gig Harbor Washington. PM me if interested.
Ron, Aristo produced 3 sizes in several styles. R1 or 4Ft Radius, 10Ft Radius and #10. Most came in either USA or Euro ties and the two larger ones were available in Stanless Steel. All code 332. They might also sold them in Aluminum for a while, but I donāt have that info.
Craig, my āfriendā is looking for the smallest frogs (prolly #4). Heās still in the planning stage to get a budget going for the project. He also has a box full of tie strips and a few pieces of rail. Just needs turnouts.
I just couldnāt remember who all made code 250 track.
Iāll have to dig around in my supplies but I might have some shorter points from Llagas that would work for your āfriendā along with the frog.
I could either sell the parts, or if the āfriendā wants them completed as turnouts we might be able to work something outā¦
JRad, the switch is a 10Ft Right Hand brass switch. I need to find a brass one to replace the one wiped out. Why could I have not been smart enough 30 years ago and planted a Crepe Myrtle in the back yard where the layout was built instead of a water oak!
Yea, I found an Aristo Craft large radius switch to replace the one the tree limb wiped out. It is new and in the box. Fortunate find to say the least!
