You will probably recall there is already a thread with a similar name that I contributed to - but it contains some nastiness and we don’t do that anymore, so I started a fresh topic.
This time of year I am always looking for smaller projects to fill a couple of weeks before the trek back to Florida. The “Emily” coach sitting on my shelf was talking to me, so I finally bought it’s cousin and got out the circular saw. (Most of these photos are on GScaleCentral.com, as they are more UK oriented, but I know you all have Emilys and are converting them to Stirling Singles - right?)
The idea is to chop 2 coaches into a Midland Railway 7-compartment coach. Something like this (a 4mm:1ft model) but without the fancy lining!
I cut the two coaches and the underframes, and here’s the result. That blue tape is holding the handle on as I switched it to make double doors for the guard/conductor. The white fill-in windows from the ‘emily’s brake’ will be inserted and glued in several windows then painted to make a guards compartment. Note on the model above that one window of the double doors is glazed - should be able to handle that.
Still got to cut the roof and glue the sides together.
