Currently cleaning the inside of LGB fishplates with Q-tips soaked by smoke fluid. It at least removes more physical dirt that some joiners got than just blowing them (haha) but it only barely shows the yellow color (most of them were the same brown as the rest of the rails from oxidization). Admittedly I didn’t do much real testing since the railroad is getting a lot of work done so testing trains is not easy.
Also, does cleaning the inner rail head improve performance at all? I have an LGB sanding pad now meaning that it should be doable but it’s still more tedious than the top of the rails so I’d rather not do it if possible.
My last question is if what I’m currently trying (drilling holes into the fishplates and screwing them in as if they’re aristo joiners) is any less effective than rail clamps? For the ones that are already screwed in, some of them are still dirty in the fishplates, and I’m considering cleaning those ones too as I’ve described, although it will be tedious work.
