I have a yellow 20670 cleaning loco with the 55021 decoder directly (push in) installed. When I run it with DCC, the engine moves forward and back no problem. But the cleaning motor does not come on no matter which function button I press. All lamps work using DC, but the flashing lights aren’t working with DCC. My guess is because the cleaning motor isn’t running.
The loco works with my analog power pack but forward movement is real slow. The throttle pack only puts out 2.5A which I am told is lower than optimal for this engine.
I have tried resetting the decoder but still no luck. The switch in the cab is in position 2.
I know I could put a more expensive decoder in there but I don’t need anything special with this engine.
Any ideas?
