Todd Brody said:
I use ExpressSHC to produce my schematics, but I’ve never had one made into a board.
Am I to understand that with fritzing I can design the schematic in the same way and it will show me how to wire this schematic on a breadboard? IOW, I don’t have to design it on their virtual breadboard. That would simplify life.
Also, will it “run” the circuit once the drawing is complete? That would simplify life even more.
Example of ExpressSHC schematic I did. Would be nice if I could run it virtually before construction/parts substitution.
From the little play I have had if you design a circuit in schematic then click on the breadboard tab the components are shown laid out with the connecting wires.
I am only making small circuits on strip board so once I have designed the circuit and it is on the breadboard I can transfer it to stripboard within the program.
I only had about 2 hours mucking around with it so I am nowhere near being an expert. There is a forum that goes with it where suggestions to improve it can be made.
