To do this, you must lock #1 and #4 axle as shown earlier! This shows the magnets in place (set them where you want them), and the screws pre-threaded into the lower firebox holes provided.
This shows the Sierra reed attached to the wires, and the .080" black styrene mount, 1.75" long X 1" wide. Holes are about .565" apart, and about 1-1/4" from the end, and a Number 30 bit.
This shows the Sierra reed hot-glued to the plate.
This shows the plate installed. The magnets are super-glued to the plastic insulator between axle halves, to one side to keep any possibility of bridging.
This is the same shot, more centered. You can just see the wires going off into the firebox on the engineer’s side. The holes in the plate can be slotted to allow for fine adjustment.
I was told many moons ago, never modify your lifestyle to suit your house, always modify your house to suit your lifestyle. TOC
