I blew the internal fuse I installed when converting my Bachman Porter to R/C so I needed to open it up. While I am in there I want to improve the chuff triggering for the Phoenix P8. When I did the original conversion I used the built-in drum/finger triggers…
This proved to be less than satisfactory at anything faster than a crawl as the brass fingers tend to float. I have plenty of left over reed switches and can come up with magnets. Before I begin I need to answer a few questions.
The current system uses 4 triggers per revolution and the P8 is programmed for 1 chuff per trigger. Would using two magnets and reprogramming the Phoenix for two chuffs per trigger give better results than 4 magnets?
If I can dig up some very thin magnets I can use the existing drum. An alternative would be to drill a hole behind a wheel and glue magnets to the back side of the wheel. The drum is easier to access so I’m leaning that way. Any opinions?
Thanks! I need to finish this quick as I want to bring it to York.
