I have several of these ESC’s ordered for critters and Bachman xmas 10 wheelers was wondering if there is another way to reverse the motor other then a servo hooked to a switch.
http://www.hobbyking.com/hobbyking/store/__9090__Turnigy_20A_BRUSHED_ESC.html
and another question for probably Tony, if 2 ecs are turned on at the same time with one tx then the tx would control both (MU)ing them correct??
if that is true if one esc is in channel 3 and the other in say 1-2 or 4, why couldn’t the two trains then be controlled at the same time in different directions?? or does an ESC have to be plugged into channel 3??
Thanks for the advice
