I’ve owned 5 Accucraft 1:20.3 AMS cars for about 3 or 4 years. Most of that time, they have been shelf queens. I’ve always suspected the flange of the wheels or the couplers. Well, the time has come to create something I can use. I’m converting them or selling the hulks. I originally bought a Gondola, it had problems and I tried to resolve then with all the latest solutions. Loosened up the trucks, put in a little piece of angle to hold the truck side frames away from dragging on the sides of the wheels. Cut a couple circles out of the springs on the trucks to loosen them up. Remove the centering springs on the couplers. All well intended and tried ideas, but this car and the 4 flat cars always seem to get bad-ordered in an “OPs Session” for uncoupling, not uncoupling or derailing. Time to resolve this. The resolution on the couplers are Kadees. It is a simple replacement with 835’s. A little super glue or epoxy on the centering springs and they even work in the coupler pockets. I do think part of the uncoupling problems and maybe even the derailing problems have to do with the chains on the disconnect bars. Those chain links are large and harsh. Close observation shows those chain links hanging up on a curve or through a turnout. This becomes a non item with the Kadees, so it is self-resolving. But if you stay with the Accucraft couplers, pay attention to those chains. I picked up some USA metal wheels from RLD Hobbies. The resolution for the refit is to take 3/32 off each end of the axle and drill the brass bearings on the side frames out to a 3/16 hole. Here are some pictures to illustrate how I did this. This is the difference between a USA and an Accucraft wheel. The Accucraft is on the left.
I ground of 3/32’s of each end of the USA wheel.
Here is the USA wheel profile 3/32’s shorter.
I cleaned up the edges first on the grinding wheel and finally with emery cloth.
The bearing on the right is drilled out, the one on the left is yet to be done.
The wheel set on the left is USA, the one on the right is Accucraft.
Here is a close up of the Accucraft wheel set.
Here’s a close up of the USA wheel set. Because of the shadows you can’t see much, but then that’s the point.
They track a lot better, don’t derail and act more like the 1:20.3 Bachmanns. I think problem resolved. Yes, I know, my track work could be better. You really didn’t have to tell me, but thanks.
