With the changes in the Aristo 6 wheeled trucks on their heavyweight passenger cars, the body mounting of Kadee couplers will be effected.
They are now using smaller wheel diameters. (Seem to be the same as their normal freight equipment)
This lowers the car by about 1/8th inch, causing the Kadee conversion mount with the flex bracket to be too low.
Kadee already was shimming the car by about a 1/16th".
I have talked with Sam at Kadee about this and he is investigating.
In the mean time, on my refurbishing project of a bunch of the cars, I’m trying a few things. I may try milling the big mount that is glued to the floor, down anout 3/16ths and see if it is closer to the correct height; although this may cause the coupler itself to be too close to the simulated diaphram.
Has anyone else seen this problem, or are all of you staying with the Talgo style coupling ?
I’m also changing the trucks to have the bolster in the centre of the trucks, so I have to body mount, with the flex bracket.
