It took me a while but I found them. There are behind the wheels and rub on the top of the hub as Barry said. I read his post a dozen times but the light didn’t go on. If you are looking for the hubs, they are the chrome axle sleeves behind the wheels. What a beast this thing is to handle. Good thing I have a fat slab of foam to roll it on and a lighted magnifier, or I never would have seen them.
Now that the battery power, radio control, and sound board installation is complete, I was able to run the beast back and forth on 5 feet of track on my work table. I noticed the locomotive pivots on the third set of drivers. All the other axles are sprung, but the third set seems to be fixed. Is this normal? It seems to that this teeter-totter effect would affect the tractive effort and cause derailments. Wow, that was a mouthful.
I must say that once the tender body was attached, the chuff sounded great. A Phoenix Sound P8 and 3 inch speaker were installed. We were able to get the optical sensors to work, and they provide a chuff every 90 degrees that the drivers turn. Thanks Tony! We understood your diagram. As this unit has an aftermarket drive reduction gearbox installed, it does a nice tie crawl.
I would prefer a deeper whistle, but this one is probably prototypical. The hand rung bell sounds great. We found the clanking of the 2nd air pump annoying, and it took us a while to figure out what it was. We were advised to change the duration and adjust the volume. There will be a modification of the sound file on the next release. I just used the programmer to turn it off, and changed the whistle and bell to manual mode.
There was a lot of fuss when the Bachmann PnP socket was introduced, but I love it. The extra solder pads along the side of the circuit board made it easy to add screw terminals for the sound board power wires, motor speed/voltage sensing wires, chuff and ground wires, and the jumper between the Revolution receiver’s headlight grounds so the front headlight stays on all the time. There is no rear light on the tender of this particular locomotive.
The coloured class light LEDs were changed to white. That proved to be the most frustrating part of the whole installation. I realized afterwards, I should have filed the channel to the lamps a little wider so two fine wires (telephone core wires) could have been installed and soldered to shortened LED leads inside the lamp base. If I had to do it again, flangeless 3mm LEDs would be used. Hindsight is 20/20.
The headlamp although made of numerous parts, proved to be impregnable as it is glued together. So the headlamp remains an ugly orange colour.
Overall this is a very impressive locomotive, and the PnP socket made it easy to re-power.
