My passenger coaches and cabooses have LGB 68333 24v bulbs in them wired up to track power through LGB ball bearing wheels. But they flicker quite badly. I would like to put capacitors in each car to stop this but all the retail options I have seen either come with the lamps (which I already have), say they are only for Analogue DC, and cost a lot of money. I am sure I can buy the capacitors and wire them into the lamp circuit for a few bucks each but I have a couple of questions.
What size cap(s) do I need? The coaches each have two of the 68333 24v non led bulbs in them hooked one after the other. Would a 1000uf 35vdc electrolytic cap suffice or are they too small? I can 20 of these for 8 bucks on Amazon. I think I only need a few seconds of charge.
The cabooses each have two of the 24v non led bulbs and two of the lantern lamps. I am not certain the voltage of the lantern lamps. I am guessing 18v. For these cars, should I run separate capacitors, one for the overhead lamps and the lanterns?
I am running DCC on a 10A Brutus for power. I have read AC volts are calculated differently from DC volts in regards to how much current they can handle but not sure how to calculate it.
Do I just solder the cap in series to the positive wire between the bearing pickup and the lamps?
Do I need anything else such as resistors or diodes?
