Kevin Strong said:
I tried their HO ground throws outdoors many, many moons ago. I hooked them to the throw bar via a springwire lever, so to get adequate throw and make it a spring switch. I found the ballast would get caught in the mechanism, jamming or breaking the ridge that moved the arm. We later switched to the Tenmille throws.
These look to have different mechanics, but I’d still worry about ballast getting in and jamming up the works.
I certainly can understand about ballast overwhelming H0 sized ground throws, but the ones I’m interested in are the oversized for 0 scale ones. Is it that the ballast makes the Delrin too abraded to work, or is it just that the rocks overwhelm the tiny H0 sized units.
Would the ballast be any more detrimental to the Delrin than to the metal of the Tenmille ones?
I think I’ll contact the manufacturer and see what he thinks, maybe even get a couple for a road test.
For some reason, the insert link didn’t work. So, www.cabooseind.com
