Thank you Fred. I appreciate your concern and I have had those thoughts as well. Our bedrooms have no direct exit (except windows near ground level), although the house does have two doors. There is no local code or ordinance that applies as this is still considered an outbuilding, which are unregulated here.
Regarding the gas, if you have seen news items of any of the recent home explosions, having a second exit would be meaningless in an explosion. A regular fire is a different situation. A propane detector should be high on my priority list as well as a good sized ABC extinguisher. Any fire to start while I am in it would likely begin small and a good extinguisher would at least provide an escape if needed.
The electricity is an extension cord, albeit a big one, plugged in to an outdoor GFCI. It can be quickly disconnected in an emergency. Again, no code compliance required because it is considered temporary power, like an RV. I did, however, follow NEC code when wiring the shop. There was no requirement for inspection.
I’m not going to loose any sleep over it
