Most of you have seen my crossings for livesteam and battery. Ray (Dunakin) needs a crossing for his RR where a siding crosses the mainline. I want as few gaps as possible in the rails so it will be reliable for the power thru the rails and integrity in the crossing itself won’t be lost. First I made a template.
I glued up the ties and will get them stained.
I milled gaps in the rail that will go on the mainline. I could of used a grinder as well, but the milling machine makes it easier.
That is it for now till the stain dries.
