Cutting one side one my new bridge
10foot long and 2 track wide 42" tall
In the middle, the engineering dept calculated all the factors, length, possible weight of two heavy
Engines with loaded cars, the weight of the bridge and weight of the track, all was calculated and the wind factor of 80 mph was added to the numbers.
All the above sounds impressive, the truth is this is what I drew up one nite in my recliner and sent to plasma cutter files.
Loaded a sheet of 11 gauge 4’ x 10’ steel on plasma, plotted drawing, pushed the button, and away it goes. I love CNC equipment.
More to Follow
Placing a 1" strap on the top edge of the bridge side, this makes it appear to be larger beams
spot welded in here and sanded down in picture Below
