After years of collecting the bits and pieces and building of my own skills and ambition I have finally started to bash them into a Beyer Garrett type locomotive. The 2 drive trains are Bachmann 4-6-0 's with all the linkages in metal and the cab and boiler is also Bachmann.
It is slow going due to the engineering hurdles and figuring out what fits and will work where. So far the front tender is attached to the chasis, the boiler has received a frame and the rear tender is about to be attached to its chasis. Still to do is to build the coal chute and to figure out a way to get the boiler and cab to pivot between the 2 drive trains and also make it so it can be easily removed for transport.
I thought about making a tote for this engine but it is 42" long so I’d rather be able to move it in 3 pieces.
One thing that I need advice for is, should I electrically link the drive trains together or leave them separate? If I should link them what is the best way to do this?
Thanks
