A few days ago, I put two pieces of solid 1/8" square brass through the boiler to act as supports for the air tanks. These were glued in place with JB Weld and left to dry. Once dry, I drilled 2 holes in each end. The hole furthest from the boiler is tapped for 0 90 bolts. The hole closet is drilled for 0 90 clearance. I decided to go ahead and paint the air tanks; they’ll get another coat when I paint the locomotive, but I wanted to make sure that everything was covered with paint. Running boards were cut from .060" styrene. I fashioned some steps from brass and bolted them to the front of each board. I cut some 1/8" x 1/64" brass strips to hold the air tanks in place. The styrene running boards were laid across the brass supports and used 0 90 hex head bolts and nuts to attach the brass strip to the inner hole.
The brass strip is wrapped around the air tank and slipped in between the running board and the brass support. A 0 90 hex head bolt holds it in place. Tapping the hole made it a LOT easier than trying to attach a nut to that bolt. (Yes, this IS the other tank.)
The brass strips hold the air tanks tightly and I haven’t even had to glue them in place. The hex head bolts look right at home on the top of the running board.
