How it all began
In anticipation of building an outdoor railway and getting my trains off the living room floor, I converted the first of my two Bachmann 10-wheelers with Phoenix sound to battery power. Because I hoped to save a few bucks and because I hate to discard something that’s perfectly good–like my Aristo Train Engineer–I opted to merely replace track power with battery power, using a neat little conversion module fellow LSC regular Del Tapparo sells for $39. I got the floor mount version, with its on-off switch, in-line fuse and a tidy terminal strip that keeps all of the various wires in place and directs their voltage and/or signal to wherever they need to go–like to the RC receiver and the Phoenix sound system. I also bought a charging plug ($10) and a battery connector ($3) so I’d have a complete package without learning after the fact that I needed something more. At Del’s recommendation, I also purchased a $49 Tenergy Li Ion battery, opting for the 14.8 volt, 2600 mAh model because of its relatively small dimensions. Then I attacked the tender and ripped out all of the track-power wiring, noting (in most cases save one) which wire went where. I also found a home for my new battery–under the coal load–and played around positioning the various components until they fit neatly on the tender deck. Then I started the tedious process (at least to me) of measuring, cutting, tinning and soldering all of the wires and plugging them into their various receptacles on the terminal strips. I could go on, but I’ll save further explanations for the photos.
Modifying the tender shell
Because the battery would be hanging from within the coal load, I installed a styrene strap to hold it in place and then used solvent cement to attach a square of styrene beneath the water filler hole where I would mount the charging jack. That way, whenever the battery needed a refresher, I could just lift the water filler lid and give that Li Ion a “drink.”
The Li Ion’s lair
OK, so I love a good pun. Sue me. Actually, here’s how the battery looks all snugged down.
How it all came out–after many nasty words and burnt fingers
My wife says that I am amazing and an electronic genius, but I tell her 'lectronics is just Tab A to Slot B-- and to Slot C, D, E, F, and G. Being anal, I tried to use different wire colors for every hookup (I think the magenta and navy blue are quite striking). The big globs kinda in the middle of the floor are the choke coils, used to supress motor noise in the radio transmission. I was gonna leave 'em out but TOC said I needed 'em. Anyway, enjoy the view.
Same scene, but with the antenna in place.
In my original track power Train Engineer installation, I wrapped the antenna wire around a piece of discarded FedX cardboard because the company paid me a stipend everytime I displayed my tender to visitors and showed the company’s logo. It’s called branding. Seriously (but why start now?), I wanted the new installation to look classy so I substituted a piece of styrene for the cardboard. Do ya think that if I mention I got it from TAP Plastics, they’ll send me free styrene sheet?
Shell and deck meet and mingle
Here’s how she looks all hooked up but still exposed. Note the battery power cable leading to the terminal strip and the charging jack, attached to the tender shell at the water filler hole.
Look, ma! She runs, dirty track and all.
What can I say? There were tears in my eyes, mostly from inhaling all them soldering rosin fumes. Hooked the loco to a 4-car train and did a few loops in forward and reverse. The sound works, kinda, but at startup, always toots three times regardless of direction. It is polarity, and thus direction sensitive, but if I don’t figure out how to make it go, I’m calling Phoenix. BTW, this is an old sound system and doesn’t have the controlable sounds (whistle, bell, blowoff, etc) of the newer Phoenix systems, so it does what it does depending on what the loco is doing (i.e. starting, stopping, slowing down). Yes, I know the rear of the tender shell is sticking up in the air. In my rush to try things out, I encountered a slight interior clearance problem. Nothing that a little extra pressure on the shell can’t fix, right?
After the dust settles and I regain my composure, not to mention get my hands on a hundred bucks or so, I’m gonna convert the other loco to battery power. I got the moves down real good.
