I’ve seen the photos of the bridges in your thread to which you added guard rails. You may be able to solve a geometry problem for me …
Here you see the “high bridge” on the Slate Creek. When the temporary bridge is replaced with the real one, it’ll have wooden ties and hand spiked rail … and I want to add guard rails. However, as you can see, there’s a curve at each end of the bridge, give or take a few inches.
While guard rails are pretty easy to lay out on straight track, how do you make the part where they come together to a point work on a curve, and make it look like it’s supposed to?
Matthew (OV)
ps. As my photos never work out, if the above won’t autolink/insert, see:
but I should get at least some small projects done!!
