Ray Dunakin said:
Looks good with the added braces!
thanks guys! ----------------------------------------NEWS FLASH------------------------------------------- The NBRR announces the addition of a new “Hybrid” Rail Truck. This is the 2nd piece of Motive Power for the line to be converted from fossil fuel to battery power. In an effort to cut down on emissions(for no known reason), the Bachmann Rail Truck has been fitted with Twelve 1.2v AA NiMH cells and an RCS Basic 2… Control is provided by a RCS TX-24. Even more energy was conserved by carrying over the LED directional lighting. The Batteries and RCS Motor Driver (charging jack, and pwr switch) are installed in the custom built crate on the rear deck, and antenna is installed on the roof of the cab.
--------------------------------------- after running for a good while yesterday…I noticed a few things… 1. This unit Does Not Like Grades. I have some pretty steep grades on the Main, and while it can traverse them, it ain’t too happy. 2. The RT surges downhill. Not a RC(S) problem, but a driveline prob as discussed with Dave Goodson (TOC). there is soo much play in the u joint you are bound to have some surging. 3. The unit is a very smooth runner on level well laid track and runs along nicely…purring away. I believe it will make a nice addition to the line, esp when I get more track laid, and it will add some variety to the motive power. I may re-do the battery install and use a sub AA type to conserve space in the crowded ‘crate’. Until then, I have a Saddle Tank to complete… cale
