Hi Steve,
The bolsters are molded into the floor as can be seen below.
For reference purposes, shown below is Aristo’s newer version lowered floor assembly kit that includes the deck. In this example the deck is brown color.
Shown below is the floor separated from the deck.
If the bolsters are cut out from an old version floor, it seems this will result with the floor having 3 separate pieces (the 2 ends & middle section). The bolsters have screws that serve to fasten it to the deck. There are screws that fasten the middle of the floor to the deck, too.
Just a heads up about Aristo floors:
As said before, Aristo’s floor assembly includes the deck that is fastened to the floor by screws. In this regard, I found early “REA” branded Aristo car decks, that were typically yellow in color, could be easily taken apart by removing the screws. However, later Aristo production runs had the decks glued in place, too, some of which are very difficult to separate from the floor.
When you are ready to install new 3-D bolsters, it seems they will fasten OK to the deck with the screws, but how will the floor end sections and much of the middle section be re-attached to the deck - maybe just with glue?
-Ted
