Which Kadee product works best for the above noted Dash-9 and the SD-45 for body mount? I’ve successfully use the 789 with slight modification, but what have all y’all used?
Steve, I haven’t tried to mount kadees on mine yet
To install Gauge 1 couplers on an Aristo-Craft Dash 9, purchase a set of Kadee 1787 or 1789 couplers. The couplers and gear boxes in these sets are the same, except for the holes in the gear box mounting tail. The only modification required is to enlarge the rear hole in the tail of the gear boxes with a 15/64th inch drill bit so they will fit snugly over the coupler mounting posts on the diesel. If you do not have a 15/64ths inch drill bit, a 1/4 inch bit can be used but the couplers may wiggle on the posts. To prevent the coupler from climbing the drill bit and boring the hole crooked, sand or file the outside walls of the coupler tail flat. Place the coupler upside-down in the jaws of a drill press vice or other suitable heavy vice and tighten snugly. Slowly drill the 15/64ths inch hole centered on the rear hole in the coupler tail.
(http://ovgrs.editme.com/files/KDDash9/Kadee.jpg)
CAUTION: DO NOT TRIM the side wall ridges off the tails of the Gauge 1 coupler boxes as shown in the Kadee instructions for the “G” scale 789 coupler set. If you do, you will have to shim the couplers to the proper height with a couple of thick washers. Assemble the Kadee couplers as illustrated in their instructions. To remove the Aristo-Craft couplers, place the diesel upside-down in a foam cradle or rolled towels, taking care not to damage the horns. Remove the small chrome screws and coupler centering springs from the mounting brackets behind the pilots. If you have trouble accessing the screws, each of the motor blocks can be removed by removing four screws on the inside of the side frames. Two of the screws are outlined in red in each of the following pictures. The motor blocks have an arrow on the top which should face the pilots when they are re-installed.
(http://ovgrs.editme.com/files/KDDash9/Front.jpg)
(http://ovgrs.editme.com/files/KDDash9/Rear.jpg)
Remove the chrome screws and washers from the coupler mounting posts and set them aside, as they will used to mount the Kadee couplers. Turn the diesel over and remove the small black screw on top of the couplers just behind the knuckle. Remove the knuckles, and then the plates that held them to their mounting posts. Re-assemble the knuckle couplers and place them, the return springs and small chrome screws in a Ziploc bag. Mark the road name, Dash 9 and the road number on the baggy and store them in the diesel’s packaging. After the Aristo-Craft couplers are removed, turn the diesel upside-down in the work cradle. Slip the Kadee couplers through the slots in the pilots and over the mounting posts. You may have to push on the coupler return spring mounting bracket a bit. Fasten the couplers with the original Aristo-Craft washers and screws. If you have 1/2 inch OD washers with a 1/8 inch hole in the center, use those in place of the original Aristo-Craft washer to minimize coupler flex on the mounting post. CAUTION: Do not use the #4 screws provided by Kadee as they will split the mounting posts on the diesel. Use only the original Aristo-Craft screws, when mounting Kadee couplers on the posts of ANY Aristo-Craft diesel.
(http://ovgrs.editme.com/files/KDDash9/Nose.jpg)
(http://ovgrs.editme.com/files/KDDash9/Tail.jpg)
The couplers will fit to the proper height and provide a wide swing without any modification to the pilots of the diesel.
Paul, Thanks, that is the information that I was looking for.
