If you want to make your DCC++ command station wireless, here is a good possibility.
I have used these EPS-01 units and they are fast and have good range. You can pick them up for at:
https://www.addicore.com/ESP8266-ESP-01-p/130.htm
Be aware there are some ESP-01 modules from other vendors that have the small IC chip with “PUYA” stamped on it. This chip is not in the esp2866 library yet officially. The above vendor has been confirmed to have the good working chips installed on the ESP-01.
Problem is the manufacturers code is not in the library to adjust the timing on how to program the chip (Spiffs).
Symptoms is it will work upon programming, but remove power and restart the ESP-01 and the program is gone.
