B'mann Lil Big Hauler high coupler to standard LGB coupler heigh
This is a quick illustration of what is needed to convert the Lil Big Haulers stock high coupler to the standard coupler height of everything else on the large scale market. With the Thomas line, Bmann stock provides 2 pair coupler mounts, one comes from the factory with hook/loop couplers at the higher position that makes the line out of the box incompatible with anything outside of the Thomas lineup, however they do provide with the Thomas lineup a second pair coupler mounts that is are thicker and once installed allows an LGB style hook/loop or Bachmann/Aristo knuckle coupler to be mounted at the standard LGB coupler height. Once this is done the Thomas line can now be coupled to any other product line that has the same type coupler. Now for whatever reason the Lil Big Hauler line also has the same high coupler mount as the Thomas line, making them incompatible with everything else, BUT unlike the Thomas stuff, they don’t NOT come with the pair of adapters that would allow the switch over to standard coupler heights. Whether this is an oversight on Bachmann’s part I cannot say, I pointed out the situation to their reps at the SWGRS, they said they were unaware of the issue but the next day they had taken the adapters from a Thomas car and mounted them to one of the LBH cars and saw that indeed it now worked with all their other non-Thomas/LBH stuff. So hopefully they will include the adapters in new shipments, but until then, or if you’ve already bought stuff and found it doesn’t work with anything else, you will have to order the replacement parts from Bachmann, unfortunately I don’t have the part number so a phone call, or use the photo in this post, to tell exactly what you need will be in order (I dont think even Bmann has a part # yet) The Bachmann forum says to call them to order them and they will work it out.
The problem as noted, you can see the difference with the LBH coupler and stock LGB height
This is the little beauty you need, its the thicker adapter provided with the Thomas line.
It mounts with another screw under the coupler mount, then the coupler screws into a second mounting hole specific for it.
Once installed the coupler is now at the same height as everything else on the large scale planet. This illustration shows conversion to Bmann knuckles, but its the same for LGB hooks and Aristo’s or any coupler that mounts to a standard LGB style coupler tang arm. I hope Bmann can include these in future shipments, its seams a real oversight in an otherwise great little addition to the large scale universe.
FYI re: ball bearing wheels, LGB BBs (with the power pickups) are a STRAIGHT SWAP and fit with no issues. Sav Val BBs are too wide and bindedup but the LGBs work perfectly.
I know this is a bit out of date, but I just got my Lil’ Hauler engine.
I am pulling a set of small passenger cars (coach and combine) behind my unit:
(http://imageshack.us/scaled/medium/594/img8597ep.jpg)
This required the use of the Thomas & Friends adapter to drop the H&L coupler on the tender to the same height as the cars. As Vic said, this matches up perfectly.
However, even with the power-pickup of the cars removed, the drag was still enough to derail the tender almost every turn. Obviously the first remedy attempt was to replace the plastic wheels with steel. I chose to go with a set of Aristo’s smoked-chrome-plated wheels. The wheels easily weighed more than the tender did. The final weight was nearly 3x as heavy as it had been. It also solved the derailment issue.
I only have the tender, but there, it was a perfect fit… just in case anyone wants to know.
JD when you can, upgrade the HLWs to ball bearing wheelsets. It makes a huge difference and with the LGBs with the built in power pickups you can easily reattach the lights.
Vic. I’m going battery power, but thanks for the suggestion.
Even using battery, switching to BBs seriously reduces the rolling resistance significantly. That alone will extend your running time, just a suggestion.
I’d think that it would be even more important in battery operation, since us track power guys don’t have the additional worry about run time or (usually) overall power consumption.
Might buy you enough extra efficiency to light the cars.
