There’s always some addition still being worked. Below are 2 pictures of the Proposed addition to the line, to run the tracks around Hilltop, to continue the Line eventually out to Okawville…
Jane and I have bee working on extending the line since the last Ops session in May, working on the extension… This work provided us with the oppertunatity to extend the EVWR local run to a simulated temperary location of Addieville…
In the below picture, hopefully, you can see where the line will come across a set of bridges and continue out to run on the trestle.
It will contibue on the trestle and cross over the lower tracks and under the upper tracks to wrap around Hilltop.
This will be the next phase of construction, along with extending the capacity of the freight yard at Evansville/Memphis area…
