Bob McCown said:
Looking good, Andy. I love the long sidings and big expansive runs.... got a trackplan yet?
Bob, I do have a somewhat idea of the trackplan... not much down on paper, as the majority of it is in my head... :)
Not sure if you can follow, but: from “Sudden Drop Bridge”, the track will go out to the tree lin in the background, then go left and cross the other waterway… it comes back, to where the skids of retating wall bricks are on the skids in the grass, and crosses back over the waterway to the other retainingwall there, then goes left to right, under itself, and out to the right, to the 20 ft temp bridge…
Basically, it will be a huge figure 8 for a mainline circle… At the 20 temp bridge, the line splits, and there my branchline starts and it will run right to left, around the retaining walls, and an interchage will be will be down on the far left retaining wall, then run back to the trees, and loop back to the front, cross under the line from “Sudden Drop Bridge”", and run back to the trees on the right side, and dead end…
Most of what I just said, you can see in the first picture on the posting… Sudden drop bridge is just behind me in that picture, running from my left to right, as I am standing in that picture…
If i get a plan on paper, small enough to fit on here, I will post it…
From the window into the basement, to Sudden drop bridge is approx 50 feet…
Warren, thanks…
